Open Music Labs Forums • View topic - Problems with FHT code
Postby taco » Wed Oct 24, 2012 12:24 pm
taco
Re: Problems with FHT code
Postby guest » Wed Oct 24, 2012 3:27 pm
to save time in the code and reduce jitter, TIMER0 is disabled by the TIMSKO = 0; line. so anything that requires TIMER0 will not work, including delay() and micros(). you can try commenting that line out, and see what it does.
also, just to check, are you using this on a MICrODEC, or an Arduino? there are some slight differences between the 2.
Postby guest » Wed Oct 24, 2012 3:48 pm
also, the cli() and sei() are there to block interrupts while it processes. im not sure why this had to be done, but with ardunio1.0 the UDRE interrupt would slow the process way down. it would take at least 10 times as long. i have no idea why that was the case. it worked fine in arduino-0022. at any rate, micros() might require that interrupt as well.
Postby taco » Thu Oct 25, 2012 9:06 am
taco
Postby guest » Thu Oct 25, 2012 10:30 pm
Postby guest » Fri Oct 26, 2012 12:26 am
ok, so after a bit of digging, it is specifically the pointer register that was causing the problem. i read up a bit on register usage:
http://www.nongnu.org/avr-libc/user-man ... _reg_usage
and it turns out that all functions that use r2:r17,r28:r29 must save and restore, and r1 must be cleared (which i was already doing). its not too much more to save everything, so i might just do that to be on the safe side anyways.
Postby guest » Fri Oct 26, 2012 1:47 am
a new file is up on the wiki
http://wiki.openmusiclabs.com/wiki/ArduinoFHT
i have yet to fix the FFT library
Postby taco » Fri Oct 26, 2012 9:51 am
Wow, thanks for fixing that so quick. It works great now! Thank so much.
taco
Postby guest » Sat Oct 27, 2012 1:18 am
thanks for finding the bug. keep us posted on how your project turns out
Postby taco » Fri Nov 02, 2012 1:40 pm
For this project, I was developing a code base that can be used by our researchers and students. I've posted a blog entry here that shows the final code:
http://vtchl.illinois.edu/node/557
Thanks!
taco
Return to Software
