Second solution worked. The mic 'seems to be quiet' - much more so than when the cap is simply bridged.
Thank you very much - time to seal the puppy up in some heat-tube and see how it performs.
I will post a message back after a few tests..
- It is currently Fri Jan 27, 2023 11:03 pm • All times are UTC - 8 hours [ DST ]
BootlegMic doesn't work...
Moderator: guest
• Page 2 of 2 • 1, 2
Re: BootlegMic doesn't work...
excellent!
definitey let us know how it goes, i think other people might want to homebrew their own as well.
Hey all.
Headed to the concert over the weekend. Big outdoor stage event.
Mixed results - I was fairly close to the stage (loud enough to need earplugs).
With that said - absolutely no distortion :)
The recording (no doubt somewhat mangled by compression) was definitely very soft, and lacks treble - presumably a resistor change could do the trick ?
- kweks
good to hear it didnt distort
the default iphone video recorder
has around 200hz to 16khz bandwidth
and there is a fair bit of compression
if it was too quiet
and you want to try making it louder
increase the value of the 470ohm resistor
try 680ohms
if it was too quiet
try 680ohms
Thanks - I'll do that.
The volume wouldn't have had anything to do with the 2.2 across the cap ?
- kweks
yeah, that will reduce the volume as well
you can try bumping it up to 4.7k
as well as up the other one to 680ohms
