Hi all,
I just want to use the DAC in the Audio Codec Shield in a way that the Arduino uno sets a digital number and we can get an analogue output.
Any approaches of how to start?
Thankx
- It is currently Fri Dec 06, 2019 6:56 pm • All times are UTC - 8 hours [ DST ]
DAC in Audio Codec Shield
• Page 1 of 3 • 1, 2, 3
Re: DAC in Audio Codec Shield
that should be pretty easy
but be sure to take your output
from the line_out solder pads
and not the headphone
the headphone output is only AC voltages
in all of the examples there is a line like this
you write your value to left_out or right_out
depending upon where you have the wire connected
Thank you, guest.
Just what I needed. It is quite simple in fact, I just did not understand well that function.
- liner
What is acceptable value (range or discrete) as an argument to the function AudioCodec_data for giving out a voltage say 3.5V or 5V? I tried passing different values for left_out as well as right_out - 125, 500 or 32767. But none of these could give me any analog out (DAC out was zero).
I tried sine_generator sketch from the examples and could see sine wave on a scope (HP_Out); adjustable freq & amplitude with the mods - so nothing wrong with the hardware setup.
Inside sine_generator -
I am not able to understand the co-relation between values in the look up table (sinetable.inc) & the generated wave.
I would also like to know how pgm_read_word_near function works?
The Arduino IDE does not show this function in orange color like others. How is that???
I tried passing values from the lookup directly to this function, but that does not work as well.
- vickyjungade
the headphone out is AC
so if you want a DC voltage that doesnt change with time
you will need to use the line_out pads
the DAC goes to 3.3v
and this is at 0x7fff = 32767
program_read_word_near() is a C function for reading values from internal flash program memory. there isnt an arduino command to do this. all it does, is fetch a value that has been stored into the program memory, at a location specified by the value that you give to the function. if you take these values and send them to left_out and right_out, they will appear at the output.
the values are signed integers, so 0x8000 = -32768 = 0v. 0x0000 = 0 = 1.65v. 0x7fff = +32767 = 3.3v. if you want to convert between signed and unsigned you can do this:
note that its the same code to go from signed to unsigend, and from unsigned to signed.
- Code: Select all
unsigned int i = 0; // declare variable
signed int j = 0; // declare variable
i = j + 0x8000; // i is now an unsigned version of j
j = i + 0x8000; // j is now a signed version of i
Ok, so we tried to substitute the call to DAC as AudioCodec_data(&left_in, &right_in, 58773, 58773); or AudioCodec_data(&left_in, &right_in, 0x7fff, 0x7fff);
& tried to read with a scope from the pad labelled OUT from its R & L. see attachment.
Yet we are not getting any voltage.
suppose we try the original sine wave program, we can read sine wave as before.
please help me out!
see we modified only 1 line:
please help me out!
- Code: Select all
sine_generator.pde
guest openmusiclabs 7.7.11
this program creates a sinewave of variable frequency and
amplitude, presented at both left and right outputs. there
isnt any interpolation, so you only get 256 discrete frequencies
across the span of 44Hz to 10kHz.
#define SAMPLE_RATE 44 // 44.1kHz sample rate
#define ADCS 2 // use both ADCs
#include <AudioCodec.h>
// even though there is no input needed, the codec requires stereo data
int left_in = 0; // in from codec (LINE_IN)
int right_in = 0;
int left_out = 0; // out to codec (HP_OUT)
int right_out = 0;
// create variables for ADC results
// it only has positive values -> unsigned
unsigned int mod0_value = 0;
unsigned int mod1_value = 0;
// create sinewave lookup table
// PROGMEM stores the values in the program memory
// it is automatically included with AudioCodec.h
PROGMEM prog_int16_t sinewave[] = {
// this file is stored in AudioCodec.h and is a 1024 value
// sinewave lookup table of signed 16bit integers
// you can replace it with your own waveform if you like
#include <sinetable.inc>
unsigned int location; // lookup table value location
// call this last if you are setting up other things
AudioCodec_init(); // setup codec and microcontroller registers
// &'s are necessary on data_in variables
// create some temporary variables
// these tend to work faster than using the main data variables
// as they arent fetched and stored all the time
int temp1;
int temp2;
// create a variable frequency and amplitude sinewave
// fetch a sample from the lookup table
temp1 = pgm_read_word_near(sinewave + location);
// step through table at rate determined by mod1
// use upper byte of mod1 value to set the rate
// and have an offset of 1 so there is always an increment.
location += 1 + (mod1_value >> 8);
// if weve gone over the table boundary -> loop back
// around to the other side.
location &= 0x03ff; // fast way of doing rollover for 2^n numbers
// otherwise it would look like this:
// if (location >= 1024) {
// location -= 1024;
// set amplitude with mod0
// multiply our sinewave by the mod0 value
MultiSU16X16toH16(temp2, temp1, mod0_value);
// our sinewave is now in temp2
left_out = temp2; // put sinusoid out on left channel
right_out = -temp2; // put inverted version out on right chanel
// get ADC values
// & is required before adc variables
AudioCodec_ADC(&mod0_value, &mod1_value);
reti(); // dont forget to return from the interrupt
- Attachments
- 2012-09-22 15.05.58.jpg (92.77 KiB) Viewed 22857 times
- vickyjungade
heres how you can use the codecshield dac
AudioCodec_data() can only take variables, not constant numbers.
- Code: Select all
dac_out_using_main.pde
guest openmusiclabs 9.22.12
this program allows the user to update the dac output in the main loop.
it also allows the user to use unsigned values. but, it does not update
the sample at every sample period, so it may not work well for playing
back wavetables or other synchronous data.
#define SAMPLE_RATE 44 // 44.1Khz
#define ADCS 0 // no ADCs are being used
int left_in = 0x0000;
int left_out = 0x0000;
int right_in = 0x0000;
int right_out = 0x0000;
AudioCodec_init(); // setup codec registers
// call this last if setting up other parts
unisgned int i; // do whatever calculating you want
left_out = i + 0x8000; // convert to signed value
ISR(TIMER1_COMPA_vect) {
also
if you want to tell me a bit more about what youre doing
i might be able to help more
We could write through the DAC properly. Thanks!
We are implementing a PID as described in http://en.wikipedia.org/wiki/PID_controller. Any suggestions?
The ADC is to read the process variable, DAC is to transmit the control value.
Please explain how to:
0. Read the ADC properly. Which pin to connect the process variable signal? We could not correctly read a DC voltage (or sine) through function AudioCodec_data, (argument &left_in or &right_in) when connected to IN as shown in attachment.
1. set the interval of the ISR that calls the read & write functions, as we have to write our functionality in loop()
2. use the 24 bit ADC & 32 bit DAC for accuracy. Please explain how to? What is the 'maximum resulution' of ADC & DAC that can be used , i mean 16 bit or 18 bit or 24 bit. We need a ADC/DAC with max code width, hence this card!
1. the range for left_in & right_in is -32768 to 32767. Also the range for left_out & right_out is the same. Besides the defination of AudioCodec_data shows that these parameters are int. Why so?
2. the AudioCodec_readme.txt says, for the function AudioCodec_ADC - "the ADC is only a 10bit ADC". Why so?
3. Also, how to read & write, ADC & DAC by calls in loop function without using interrupt
- Attachments
- 2012-09-23 16.30.56.jpg (99.13 KiB) Viewed 22844 times
- vickyjungade
a PID controller sounds awesome
for that you will want to do all the processing in the ISR. it is important that the data gets processed in a synchronous fashion, and you could do it in the main loop, but it is easier and faster to do it in the ISR. here is some code that can get you started. your input signal will need to go from 0v to 3.3v.
- Code: Select all
dc_controller.pde
guest openmusiclabs 9.23.12
this takes in a dc value from the codecshield, processes it, and
sends out a dc value on the codecshield.
#define ADCHPD 1 // set the codecshield to DC input
int last_value = 0;
int difference = 0;
int integral = 0;
int position = 0;
difference = left_in - last_value; // create a difference signal
position = left_in; // create a position signal
integral += left_in; // create an integral signal
last_value = left_in; // backup the last value
// do the math here for pid
// dont forget to return from interrupt
