- Code: Select all
left = (temp_spi[0] << 8) | temp_spi[1];
right = (temp_spi[2] << 8) | temp_spi[3];
- It is currently Thu Dec 05, 2019 11:03 pm • All times are UTC - 8 hours [ DST ]
[SOLVED]Audio codec shield with Arduino Due
So,What is left_in,left_out, right_in and right_out in this code? How do I manipulate these to just echo and playback with little delay like in the example fixed_delay etc. I could not understand when you wrote this
- youthreewire
- Code: Select all
left_in = (temp_spi[0] << 8) | temp_spi[1];
right_in = (temp_spi[2] << 8) | temp_spi[3];
- Code: Select all
temp = left_out;
temp1 = right_out;
temp_spi[0] = SPI.transfer(10,highByte(temp),SPI_CONTINUE);
temp_spi[1] = SPI.transfer(10,lowByte(temp),SPI_CONTINUE);
temp_spi[2] = SPI.transfer(10,highByte(temp1),SPI_CONTINUE);
temp_spi[3] = SPI.transfer(10,lowByte(temp1),SPI_LAST);
So what could be connection diagram for Due? I2C I know.
- youthreewire
i dont know much about the DUE, i dont own one and have never used one. if you find an I2S library for it, that will probably also have a connection diagram.
You mentioned this code left_in and right_in
But where are we mapping left_out and right_out in the device? You just declared them as temp variables. Like in your library the audio_codec_init function takes all these four parameters but here how do we map it?
- Code: Select all
- youthreewire
I want to convert this function.I understand the following code attempts to do what AudioCodecMega_data( does.
AudioCodecMega_data( function definition from official library:
The code for Due which attempts to as the above code but no knowledge of _rout/right_ out and _lout/left_out
- Code: Select all
static inline void AudioCodecMega_data(int* _lin, int* _rin, int _lout, int _rout) {
int _out_temp = _lout;
PORTB |= (1<<PORTB0); // toggle ss pina
asm volatile ("out %0, %B1" : : "I" (_SFR_IO_ADDR(SPDR)), "r" (_out_temp) );
PORTB &= ~(1<<PORTB0); // toggle ss pin
while(!(SPSR & (1<<SPIF))){ // wait for data transfer to complete
asm volatile ("out %0, %A1" : : "I" (_SFR_IO_ADDR(SPDR)), "r" (_out_temp) );
asm volatile ("in r3, %0" : : "I" (_SFR_IO_ADDR(SPDR)) );
_out_temp = _rout;
asm volatile ("in r2, %0" : : "I" (_SFR_IO_ADDR(SPDR)) );
asm volatile ("movw %0, r2" : "=r" (*_lin) : );
asm volatile ("movw %0, r2" : "=r" (*_rin) : );
- Code: Select all
void TC3_Handler()
TC_GetStatus(TC1, 0);
temp = random(65535);
temp1 = left_out;
temp2 = right_out;
temp_spi[2] = SPI.transfer(10,highByte(temp),SPI_CONTINUE);
temp_spi[3] = SPI.transfer(10,lowByte(temp),SPI_LAST);
- youthreewire
_rout is only needed because the code is in the library, otherwise just declaring your variable right_out is enough.
the very first hit on google for "arduino due i2s library" gave me this:
https://github.com/delsauce/ArduinoDueHiFi (which is linked from the arduino website itself as the reccomended i2s library, so it probably works)
if you are going to spend a bunch of time getting a library to work with the codec shield, you might as well have a good starting point.
I have seen the I2S library and I wanted to mention the same but you already did. I think your code is straightforward. I have most of them ported but just the AudioCodecMega_data function has to be ported.I do not understand what you are trying to do in the assembly here.I found one more thread but incomplete here:
http://forum.arduino.cc/index.php?topic=267937.0
So left_out and right_out are used in the functions so how do I replicate it through here
How will the codec know how to pipe out right_out and left_out?If we just declare them as variables it wont be sufficient. They are to be written to some registers of the WM8731.
- Code: Select all
void TC3_Handler()
temp1 = left_out;
temp2 = right_out;
- youthreewire
Also you are using Timer1 in the library and connected one pin SS to T1 in atmega328. In the mega library people changed it to Timer 5 and connected it to T5. Now as the per the new code for Due. TC1 and TC3 Handler are being used so which pin will correspond in functionality to T1 or T5.
- youthreewire
guest wrote:
- Code: Select all
- Code: Select all
temp = left_out;
temp1 = right_out;
Could you tell me more clearly as to how the left_in is being mapped to left_out. Because WM8731 should also know how to set its output. Dont you think we have to use SPI to write the output out as well.
- youthreewire
