Open Music Labs Forums • View topic - [SOLVED]Audio codec shield with Arduino Due
Postby youthreewire » Thu Jun 11, 2015 7:16 am
youthreewire
Postby guest » Thu Jun 11, 2015 11:21 am
Postby youthreewire » Sat Jun 13, 2015 7:27 am
So what could be connection diagram for Due? I2C I know.
youthreewire
Postby guest » Sat Jun 13, 2015 11:58 am
i dont know much about the DUE, i dont own one and have never used one. if you find an I2S library for it, that will probably also have a connection diagram.
Postby youthreewire » Sun Jun 14, 2015 5:06 am
youthreewire
Postby youthreewire » Sun Jun 14, 2015 6:00 am
youthreewire
Postby guest » Sun Jun 14, 2015 12:32 pm
_rout is only needed because the code is in the library, otherwise just declaring your variable right_out is enough.
the very first hit on google for "arduino due i2s library" gave me this:
https://github.com/delsauce/ArduinoDueHiFi (which is linked from the arduino website itself as the reccomended i2s library, so it probably works)
if you are going to spend a bunch of time getting a library to work with the codec shield, you might as well have a good starting point.
Postby youthreewire » Sun Jun 14, 2015 9:18 pm
youthreewire
Postby youthreewire » Sun Jun 14, 2015 10:53 pm
Also you are using Timer1 in the library and connected one pin SS to T1 in atmega328. In the mega library people changed it to Timer 5 and connected it to T5. Now as the per the new code for Due. TC1 and TC3 Handler are being used so which pin will correspond in functionality to T1 or T5.
youthreewire
Postby youthreewire » Sun Jun 14, 2015 11:38 pm
youthreewire
