Open Music Labs Forums • View topic - FHT to frequency
FHT to frequency
Moderator: guest
Forum rules
Due to heavy spam, new user registration has been disabled. Hundreds of posts from this sub-forum were accidentally lost in the pruning process.
FHT to frequency
Postby jbolfiil » Tue Jan 20, 2015 5:35 pm
I am trying to get the FHT converted to frequency. I saw that the formula was k*(samples/FHT_N) but I can't seem to get what I want...
1. Does k need to be unsigned? I am getting negative values when ever I try to print it out to the serial monitor.
2. How do you find out what the sampling rate is? I have read that you need to look at the prescalar but I am not sure what that is.
I am just trying to write a high on a digital pin when a certain frequency is present. Any help will be appreciated!
Also, will I need to set a magnitude threshold somehow? I only want the high on the digital pin when there is an intentional sound.
(I just realized that I did not bias the signal so that maybe a cause for off numbers.)
jbolfiil
Re: FHT to frequency
Postby guest » Tue Jan 20, 2015 9:14 pm
so to figure out which bin relates to what frequency, you need to know the sample rate. if you are using the default example from the library, that is 38kHz.
Frequency(k) = (k)*(sample_rate)/(FHT_N)
k is just the bin number.
if you want a pin to go high based on a certain frequency, just figure out which bin that is, and then check the value in that bin compared to a threshold, and set the pin high if its above the threshold
Postby jbolfiil » Wed Jan 21, 2015 11:01 am
jbolfiil
Postby guest » Wed Jan 21, 2015 2:01 pm
Postby jbolfiil » Wed Jan 21, 2015 8:40 pm
jbolfiil
Postby guest » Thu Jan 22, 2015 12:04 am
Postby jbolfiil » Fri Jan 23, 2015 4:06 pm
jbolfiil
Postby guest » Fri Jan 23, 2015 4:17 pm
Postby jbolfiil » Sat Jan 24, 2015 12:37 pm
jbolfiil
Postby guest » Sat Jan 24, 2015 9:42 pm
Return to General
