Open Music Labs Forums • View topic - Squealing alpha
Squealing alpha
Squealing alpha
Postby davehayden » Mon Oct 28, 2013 3:06 pm
I ordered a Mixtape Alpha board from OSHPark (looks great in purple and gold!) and put it together this morning without much trouble. The mixtape.hex flashed and verified via avrdude without any problem. When I power it up, though, it screams at around 3800 Hz, just ear-splitting. I tried mixtape_avr_new.hex instead and it's even worse. The buttons react as expected, and they change the noise it's making (usually louder and more painful), but it's always got that 3800 Hz tone going.
Any thoughts?
AGGGGGH! MAKE IT STOP!
davehayden
Re: Squealing alpha
Postby guest » Mon Oct 28, 2013 6:58 pm
did you set the fuses? im betting the CK/8 fuse hasnt been cleared. there are a few other fuses that need setting as well, you should take a look at the top of the .asm file for the correct fuse settings. awesome job, by the way. and definitely use the new_experimental.hex.
Re: Squealing alpha
Postby davehayden » Tue Oct 29, 2013 11:24 am
That was it! Thanks so much! We'll be putting the other 2 boards together tomorrow at our local hackerspace open night, really glad to have this sorted before then. My hope is we can get some visual artists interested in doing custom art for a second batch.
Here's how they came out:
I don't see new_experimental.hex in the files section on the wiki. Is that the same as mixtape_avr_new?
Thanks again for the help, and bigger thanks for making this open source! I can't wait to start poking at the code and figure out how this thing works. :)
davehayden
Re: Squealing alpha
Postby guest » Tue Oct 29, 2013 11:37 am
yeah, i changed the name on the link so it would be less confusing. its the V2.0 files.
the mixtape looks great. be sure to clean the board really well, as the flux can make it work poorly. also, if you end up doing another run, you may want to tent your vias, as it gives the surface a cleaner look. did you make those straight from the gerber files? or did you rerun the gerbers from the eagle files?
Re: Squealing alpha
Postby davehayden » Tue Oct 29, 2013 3:00 pm
I made a couple of tweaks in Eagle—used a different battery clip I had laying around, and changed the ISP header for pogo pins.
Good point about the vias, thanks!
davehayden
Return to Mixtape Alpha
