Hi,
These Vampires are really great little suprises.
I was considering ordering a Vampire II, but I have two questions :
- What is the state at startup ? Is it the last state before powering down or do I have to edit the 4 sounds each time I power up ?
- Will it work using a MIDI Thru Box ? Or the Midi Thru output of another synth ?
- It is currently Thu Jan 26, 2023 7:25 pm • All times are UTC - 8 hours [ DST ]
status at startup
Re: status at startup
great questions.
1. status at startup: this is hardwired into the program memory, so it does the same thing every time, which is a pain. it would be nice if it could save state, but the power consumption was just a bit too much. it might have been possible, but it could have induced erratic behaviour when saving.
2. midi-thru: it should be able to be powered by midi-thru, as long as they follow the midi spec. i am not sure about the midi-thru on a bus powered device. the midivamps do not consume all the power available from the midi line, so as long as the other bus powered device only takes a small bit, it might work.
Since all edits are not saved inside the synth,is there a way to midi out and dump the current state?Even if by trace soldering and cutting?Also you mention midi thru.I want to daisy chain 16 modules( 8 V1s and 8 Vlls).What would I need to do to the circuit board in order to do that?
- pianokeyjoe
there is no way to midi-out without rewriting the code and adding hardware. at that point it would be easier to rewrite the state-storing.
(oops double post)
- bleo
yes, they all should be listed in one section near the beginning of the code. the $ff in that example is the value, so changing that to $5a, for example, would shorten the attack.
Excellent. Next step will be figuring out how to compile the .hex!
- bleo
