Open Music Labs Forums • View topic - Shield Pinout
Shield Pinout
Shield Pinout
Postby jimmyboy » Wed Apr 10, 2013 2:25 pm
What pins does the codec shield use on the arduino and what are their functions?
thanks
jimmyboy
Re: Shield Pinout
Postby guest » Thu Apr 11, 2013 3:28 am
the full schematic can be found here:
http://wiki.openmusiclabs.com/wiki/Audi ... _schem.png
it uses:
5V , GND, 3.3V - power rails
A0, A1 - pots
A4, A5 - I2C
D5 - codec clock input
D10, D11, D12, D13 - SPI
Re: Shield Pinout
Postby jimmyboy » Wed Apr 17, 2013 2:56 pm
Thank you, guest -
I am attempting to create a code that would be able to select between the different effect examples given for the audio codec. I am using a 6-position switch to accomplish this which I have successfully gotten to work with the Arduino. The problem is that I do not really understand the ISR function. I was attempting to make a while(switch position) loop to call the different effects. Is this possible? If so, will you give me some advice on how to accomplish this? Is there a way to implement these effects without using an interrupt? I appreciate the help!
jimmyboy
Re: Shield Pinout
Postby guest » Thu Apr 18, 2013 8:07 am
Re: Shield Pinout
Postby agprimatic » Mon May 20, 2013 10:28 am
agprimatic
