First C Software
First C Software
Postby mcanulty » Sat Sep 18, 2010 6:27 pm
I'm uploading my first C software so people can start experimenting with writing their own functions. So far I've only implemented writing the first 16 bits of the SRAM, that can be easily improved. There's a delay function, an area for processing inputs to scale values, a switch case function for determining which audio program to use in the interrupt and other goodies including serial communication protocols which aid debugging to no end.
There's an AVR Studio with AVR-GCC project file here:
AVRStudio_MICrODEC_09172010.zip
AVR Studio project - zip file
(75.96 KiB) Downloaded 709 times
and an X-Code with AVR Crosspack project file here:
Xcode_MICrODEC_C_09172010.zip
X-Code Project with AVR Crosspack - zip file
(195.35 KiB) Downloaded 631 times
Re: First C Software
Postby mcanulty » Sun Sep 19, 2010 8:10 pm
I have 18b address functions implemented now, and tested them with the delay. Not releasing them right away because I haven't decided if they need some more optimization in the long run, but if you'd like to get started with 18b let me know.
Postby mcanulty » Fri Oct 01, 2010 6:03 am
psyched to say that tomorrow I will upload code that allows you to write audio functions with nice clear syntax like this:
void updownsweepPot18b(void)
   updateAudioInAudioOut();  //most efficient packing
   if (direction == 1)
      decreaseReadOffsetBy(2);
      if(atTopOfBuffer())
         readOffsetLSB = 0x04;
         direction = 0;
   else
       increaseReadOffsetBy(4);
      if(atBottomOfBuffer()) //tests for exceeding Buffer Size
         direction = 1;
   calculateReadAddressFromOffset();
   if (ADCValueChanged )
      calculateBufferSizeFromADC();
      ADCValueChanged = 0x00;
   // mod2 check here
   mod2Check();
Return to Software
