Calibrating with Pacemaker on
Postby Altitude » Sat May 24, 2014 2:50 pm
So in the instructions, it indicates that all that is needed to run the device with pacemaker off (with jumper wires as they are) is just jumpers to the tune pot. Is that it? I am not getting any audio out but CV is getting to the board and I can measure the OSC changing when I play different keys. I sense I am missing something
Altitude
Re: Calibrating with Pacemaker on
Postby guest » Mon May 26, 2014 1:11 am
sorry about that, i think the instructions need to be descriptive. the audio comes out on J6, so you can probe for it there while tuning - it wont come out the filter or VCA output though. you mentioned you saw the OSC changing, with CV, so it sounds like board is working.
Postby Altitude » Mon May 26, 2014 5:18 am
ah. Figured it must have been something like that. Working fine. VCA seems very clicky, is that to be expected?
Altitude
Postby guest » Mon May 26, 2014 3:16 pm
the VCA might be a bit clicky on some, as there wasnt an option for "selected" transistors. so the offset voltage could be a little higher. the offset voltage trim mod should take care of it, if its not tolerable.
Postby Altitude » Mon May 26, 2014 3:52 pm
That's what I was hoping for. Which parts/pins should get the trimmer?
Altitude
Postby guest » Tue May 27, 2014 2:59 am
you can put the resistor/trimmer on J9 - pin1.
Return to x0x
Users browsing this forum: No registered users and 2 guests
