Open Music Labs Forums • View topic - [SOLVED]Audio codec shield with Arduino Due
Postby guest » Sat Jul 11, 2015 10:28 am
Postby youthreewire » Sat Jul 11, 2015 7:49 pm
That piece of code just counts the ISR serviced. I removed it in my latest fix. But as you said a delay in the ISR should not effect the frequency at which ISR appears.It is strange.
Postby youthreewire » Wed Jul 29, 2015 11:24 pm
Postby youthreewire » Wed Jul 29, 2015 11:25 pm
I remember you telling me that the codec in your shield is working in DSP mode B. How do I set it to I2S mode ?
Postby youthreewire » Thu Jul 30, 2015 4:10 am
Postby guest » Thu Jul 30, 2015 10:54 am
on the codecshield, there is only 1 BCK and 1 LRCK, but the DUE has 2 of each. how are you connecting these up? also, be sure to setup the DUE as I2S master. then take a look at the signals on the scope to see if they look right (match the format shown in the datasheet).
Postby youthreewire » Thu Jul 30, 2015 11:34 pm
Back to the old code(not using the Hi-Fi ibrary) ,I am attaching the scope plots. The yellow one is the SS (slave select) pin wave and the green one is the SPI clock.Their units are also different.One is in micro seconds where as the other is in nano seconds.I dont know if the graphs are right and mean what you mentioned that the SS pin cycle needs to match with the first clock cycle of the SPI.
zoomed in
zoomed out.
The SS pin high (yellow) appears to come before the SPI transfers(green) but I do not know what the alignment should look like
Postby youthreewire » Fri Jul 31, 2015 2:04 am
Should it look like this?I dont know what correspond to what? Is the LRC the SS pin wave? And BCLK the SPI Clock?
clock wm8732 DSP mode B.jpg (40.25 KiB) Viewed 9910 times
Postby youthreewire » Fri Jul 31, 2015 2:12 am
Postby youthreewire » Fri Jul 31, 2015 3:24 am
