Open Music Labs Forums • View topic - [SOLVED]Audio codec shield with Arduino Due
Postby youthreewire » Sat Jul 04, 2015 1:30 am
I also used attachinterrupt function but it is still slow.I think I might need to use assembly code to make it run faster. I am still surprised that the arduino 328/atmega2560 is able to track a 11Mhz CLKOUT signal and still is able to communicate over serial port. Due as per it specs is far ahead that arduino/atmel 328 but still I dont get the desired performance when it comes to tracking an external clock signal for interrupts.
Postby youthreewire » Sat Jul 04, 2015 2:28 am
I check the effect on CLKOUT signal on the Mega arduino and the time period for a GPIO pin toggle on interrupt from CLKOUT is 3.7Khz. So I think Due should work as this interrupt based GPIO toggling is not the same frequency as CLKOUT frequency. Using Due I got a 76 Khz wave and 142Khz wave. I think at 3.7Khz there is enough time for the atmega328/atmega2560 to do serial communication.I think I might have to reduce the timer update to 3.7 khz on the Due and then serial communication might work. What do you say?
Postby youthreewire » Sat Jul 04, 2015 3:55 am
So I think the right question would is can we set a clock divider when using an external clock for timer interrupt.If I can set the divider and make the interrupt fall around a time period of 3.7Khz then I can do serial communication easily with the Due.
Postby youthreewire » Sat Jul 04, 2015 5:45 am
Postby youthreewire » Sat Jul 04, 2015 6:07 am
In the latest test which I conducted over 30-40 iterations I am getting the timer period as 6us. So the frequency of the wave is 1000000/6 = 166khz. I think it is too high and not giving time for the serial comm in the main loop to finish.
I am able to set it to internal clock and vary the time period and frequency but I am not able to do so with the external clock signal given as timer interrupt..
Postby youthreewire » Sat Jul 04, 2015 11:12 pm
Postby guest » Sun Jul 05, 2015 9:17 pm
so, is TC_SetRA the clock divider? does the pin toggle at 11MHz/TC_SetRA? if you apply a slower clock to that pin (instead of the codecshield clock), does it reduce rate accordingly (this will verify that the counter is responding to the external clock, and not an internal one).
Postby youthreewire » Sun Jul 05, 2015 10:03 pm
Even in Atmega328 or Arduino uno the pin does not toggle at 11Mhz. The ISR works at 3.7Khz. Now I did something new and I am able to toggle the LED at 3.67Khz.So I am hoping that it will work now.I had to set the baud at 1000000 bps and this changes the time period of the ISR toggle. Now I will invert the SS pin and see if I am able to read the sound data.
Postby youthreewire » Mon Jul 06, 2015 8:39 am
I just got SPI synced with external clock.
Postby guest » Mon Jul 06, 2015 9:10 am
glad to hear the SPI is now working. are you able to pass data?
also, the output rate should be ~11MHz/256 = 44.1kHz. i think the input clock is divided down to 5.6MHz, so the divide ratio is actually 128 to get a 44.1kHz interrupt rate.
also, digitalwrite() may be too slow for toggling the SS pin. if this ends up being the case, you should look into direct pin manipulation.
