- It is currently Fri Jan 22, 2021 6:43 pm • All times are UTC - 8 hours [ DST ]
[SOLVED]Audio codec shield with Arduino Due
So what could be connection diagram for Due? I2C I know.
- youthreewire
i dont know much about the DUE, i dont own one and have never used one. if you find an I2S library for it, that will probably also have a connection diagram.
- guest
- Site Admin
_rout is only needed because the code is in the library, otherwise just declaring your variable right_out is enough.
the very first hit on google for "arduino due i2s library" gave me this:
https://github.com/delsauce/ArduinoDueHiFi (which is linked from the arduino website itself as the reccomended i2s library, so it probably works)
if you are going to spend a bunch of time getting a library to work with the codec shield, you might as well have a good starting point.
- guest
- Site Admin
Also you are using Timer1 in the library and connected one pin SS to T1 in atmega328. In the mega library people changed it to Timer 5 and connected it to T5. Now as the per the new code for Due. TC1 and TC3 Handler are being used so which pin will correspond in functionality to T1 or T5.
- youthreewire
