Open Music Labs Forums • View topic - Control pot voltage when using with maple
Postby Pheelios » Thu Sep 25, 2014 4:58 am
I have bought a codec shield to use with Maple but was wandering whether I needed to hack it so that the control pots range from 0-3.3v and not 0-5v as in the standard configuration as Maple operates at 3.3v.
Also are there any other changes that would need to be hacked for maple or does the level translator chip take care of it.
Pheelios
Re: Control pot voltage when using with maple
Postby guest » Thu Sep 25, 2014 12:33 pm
the maple only has 3.3v on its power header, so everything just works, no hacking required.
there are some issues with the maples serial.usb, so if it seems like it isnt programming, just load programs anyways (you might have to put it into bootload mode right before manually), but it should load. the software complains, but the hardware works. there are some posts about this on the forum. hopefully it wont be an issue for you.
Postby sarakhan » Fri Nov 07, 2014 10:29 pm
before reinstating the the buffer.
You can easily check out our best quality exam you well for the real pmp exam. You can also get success in real exam of with the quality questions and ccie voice
sarakhan
