Adding a Tap Tempo
PostPosted: Thu Sep 27, 2012 5:45 pm
by diydsp
Hey folks!
Here is a basic tap tempo program you can run on the Audio Codec Shield with Maple. Just attach a momentary contact switch between +3.3V and GPIO pin 17 of the audioCodecShield. That's J1, pin 3 and J2, pin 4.
the code works up to a point- after 4 taps, it requires a timeout before it will start reading taps again.
tap tempo based on
sine_generator.pde (MAPLE)
guest openmusiclabs 7.13.11
this program creates a sinewave of variable frequency and
amplitude, presented at both left and right outputs. there
isnt any interpolation, so you only get 256 discrete frequencies
across the span of 44Hz to 10kHz.
#define SAMPLE_RATE 44 // 44.1kHz sample rate
#define ADCS 2 // use both ADCs
// note the Maple library
#include <AudioCodec_Maple.h>
// even though there is no input needed, the codec requires stereo data
// note the uint16 typedef, there is no "unsigned int16" type
int16 left_in = 0; // in from codec (LINE_IN)
int16 right_in = 0;
int16 left_out = 0; // out to codec (HP_OUT)
int16 right_out = 0;
// create variables for ADC results
// it only has positive values -> unsigned
uint16 mod0_value = 0;
uint16 mod1_value = 0;
// create sinewave lookup table
// note the int16, ints are 32b in Maple land
int16 sinewave[] __FLASH__ = {
  // this file is stored in AudioCodec_Maple.h and is a 1024 value
  // sinewave lookup table of signed 16bit integers
  // you can replace it with your own waveform if you like
  #include <sinetable.inc>
uint16 location; // lookup table value location
// Tap Tempo stuff
const int digitalInputPin = 17;
#define NUMBER_OF_TAPS 4
int32 gateTime[NUMBER_OF_TAPS] = {0};
int32 gateTimer=0;    // time since last tick
int32 dbTimer=0;      // debounce
int32 activeTimer=0;  // how long until tap sequence is abandoned
int   activeTimerMax=44100;  // how long until tap sequence re-started
int32 gateNumber=0;   // how many taps accumulated so far
int   dbTimerMax= 1000; // noise debounce interval
int32 tapSequenceTimer=0;
int16 tapTempo(void);
#define TAP_IDLE 0
#define TAP_ACTIVE 1
int16 tapState = TAP_IDLE;
// periodic beep sound
int32 beepCountdown=0;
int32 beepCountdownMax = 22050;
int32 beepLen=1000;
void setup()
  SerialUSB.end(); // usb conflicts with the codec in this mode
                   // a different operating mode which allows both
                   // is in the works
  // setup codec and microcontroller registers
  AudioCodec_init(); // call this last if you are setting up other things
  // for tap tempo switch
  pinMode(digitalInputPin, INPUT_PULLDOWN);
void AudioCodec_interrupt()
  // &'s are necessary on data_in variables
  // create some temporary variables
  // these tend to work faster than using the main data variables
  // as they arent fetched and stored all the time
  int16 temp1;
  // create a variable frequency and amplitude sinewave
  // fetch a sample from the lookup table
  temp1 = sinewave[location];
  // step through table at rate determined by mod1
  // use upper byte of mod1 value to set the rate
  // and have an offset of 1 so there is always an increment.
  location += 1 + (mod1_value >> 8);
  tapTempo();
  // if weve gone over the table boundary -> loop back
  // around to the other side.
  location &= 0x03ff; // fast way of doing rollover for 2^n numbers
                      // otherwise it would look like this:
                      // if (location >= 1024) {
                      // location -= 1024;
  // set amplitude with mod0
  // multiply our sinewave by the mod0 value
  // since it returns a 32bit value it needs to be scaled with ">> 16"
  temp1 = (temp1 * mod0_value) >> 16;
  left_out = temp1; // put sinusoid out on left channel
  right_out = 0;
  if((++beepCountdown)>=beepCountdownMax)
    beepCountdown = 0;
  int sineEnv;
  if(beepCountdown<beepLen)
    sineEnv=1;
  } else
    sineEnv=0;
  left_out = left_out * sineEnv;
  // get ADC values
  // & is required before adc variables
  AudioCodec_ADC(&mod0_value, &mod1_value);
  int v = digitalRead(digitalInputPin);
  if(dbTimer>0)  // there was a trigger so wait a bit for clearing
    if(v==0){   // only decrement if button is not pressed
      dbTimer--;
  switch(tapState)
    case TAP_IDLE:
    if( (v==1) && (dbTimer==0) ) // only accept click if first in a while
      dbTimer              = dbTimerMax;
      activeTimer          = activeTimerMax;
      gateNumber           = 0;
      gateTime[gateNumber] = 0;
      tapSequenceTimer     = 0;
      tapState             = TAP_ACTIVE;
    break;
    case TAP_ACTIVE:
    tapSequenceTimer++;  // keep track of time when tap is active
    if((--activeTimer)<=0)  // haven't tapped for a long time?
      if(gateNumber<3){
        gateNumber           = gateNumber + 1;
        gateTime[gateNumber] = tapSequenceTimer;
        // now do tempo calc
        int32 i,tapAcc=0;
        for(i=1;i<=gateNumber;i++)
          tapAcc += gateTime[i] - gateTime[i-1];
        beepCountdownMax = tapAcc / gateNumber;
        beepCountdown    = 0;
    break;
