Open Music Labs Forums • View topic - Playing arbitrary waveforms and/or .WAV files
Postby GoVirtual » Sat Jun 02, 2012 9:13 pm
Just got my shiny new Audio Codec Shield today and have been playing with is using a Maple.
All of the examples work as described, very neat project.
Question: does this shield provide for the ability to create custom waveforms/sounds, and can I play a .WAV file through the output somehow? If so, is there a pointer in the documentation or library for this?
Thanks in advance
GP
GoVirtual
Re: Playing arbitrary waveforms and/or .WAV files
Postby guest » Sun Jun 03, 2012 12:20 pm
Postby GoVirtual » Sun Jun 03, 2012 7:02 pm
Thank you for the reply.
How about dynamically generating tones at specific intervals and frequencies? Is this something that can be done natively by the library without having to load an external wavetable?
For example, if I wanted to generate a 200Hz sound on the left channel and a 190Hz sound on the right channel, both of which persist for exactly one second, is that possible using this method?
GoVirtual
Postby guest » Sun Jun 03, 2012 7:09 pm
we dont have a "tone" library right now
but it shouldnt be bad to hack something like that
the sine_generator example makes tones of variable frequencies
controlled by one of the mod pots
you could set the frequency instead by a fixed value
and then have it go through the loop a fixed number of times
Postby chipaudette » Sun Jun 10, 2012 5:25 pm
You could totally compute your waveform on-the-fly if that's what you wanted to do. Granted, it is certainly faster and easier to use wavetable lookup than to call the sine function from the C math library, but at the Maple's fast speed, I bet it can do a sine call within the interrupt service routine.
If it turns out that it's not fast enough (which would surprise me), you can use the wavetable lookup to generate a sine at arbitrary frequencies. The example code is intended to be simple, so it ends up discretizing the available frequencies by quite a bit. If you want to do (nearly) arbitrary frequencies, google "32-bit phase accumulator wavetable". When i did the search, I liked the article that showed up from Nuts and Volts (http://nutsvolts.texterity.com/nutsvolt ... pg=29#pg29).
Depending upon how much experience you have in this area, you may need to do more reading (or less) to do this phase accumulator thing as a method of better using a wavetable. So, as I said at the beginning, you can probably just use the sine function from the math.h C/C++ library and not have to deal with any of these complications.
Good luck.
Chip
chipaudette
Postby vaxon » Mon Jun 11, 2012 10:24 am
Its not too tough to convert Wavs to csv.
Cool Edit pro 2 can output ascii. then you can take that, put it in a spreadsheet to convert the numbers to integers, then open that file in a text editor that can replace line breaks with commas.
(The program "Wavosaur" as well as a few others can output text as well but always gave me weird results. Cool Edit always worked and reminded me of the '90s so I went with it.)
I'm sure there's a much simpler way if I made a pyton script or something but this gets the job done.
vaxon
