sketch: a simple comb filter for Maple
PostPosted: Tue Aug 23, 2011 10:23 pm
by okie
#define SAMPLE_RATE 44
#define ADCS 2
#include <AudioCodec_Maple.h>
int16 left_in = 0;
int16 right_in = 0;
int16 left_out = 0;
int16 right_out = 0;
uint16 mod0_value = 0;
uint16 mod1_value = 0;
#define MOD_RANGE 65536
#define BUFFER_SIZE 4096
int16 buffer[BUFFER_SIZE];
uint16 location = 0;
  SerialUSB.end();
  AudioCodec_init();
  while (1);
void AudioCodec_interrupt() {
  AudioCodec_ADC(&mod0_value, &mod1_value);
  buffer[location] = (left_in - buffer[(location + mod0_value/(MOD_RANGE/BUFFER_SIZE))%BUFFER_SIZE]*31)/2/32;
  left_out = 4*buffer[location]; //multiply by 4 because it's too quiet
  right_out = left_out;
  location = (location + 1)%BUFFER_SIZE;
Re: sketch: a simple comb filter for Maple
PostPosted: Wed Aug 24, 2011 10:16 pm
ill give it a try
looks good
why do you think the volume is low from memory
PostPosted: Sun Apr 01, 2012 8:18 am
by loss1234
Any chance of this getting converted to arduino??
PostPosted: Sun Apr 01, 2012 10:38 pm
not too much needs to change
first the correct header file needs to be included
so change
to
#include <AudioCodec.h>
also since there is only one mod being used
#define ADCS 2
should be
#define ADCS 1
and
should be
AudioCodec_ADC(&mod0_value);
and the memory is smaller so
becomes
#define BUFFER_SIZE 800
and you dont need this
SerialUSB.end();
that takes care of all basic maple vs arduino differences
now the processing speed differences
there is no hardware divide on arduino
so you can not use divide in any of the functions
unless you are dividing by a factor of 2
so the interrupt loop will look something like this
ISR(TIMER1_COMPA_vect, ISR_NAKED) {
  uint temp1 = location + (mod0>>6);
  if (temp >= BUFFER_SIZE) {
    temp -= BUFFER_SIZE; // reset location
  int temp2 = buffer[temp1];
  buffer[location] = (left_in >> 5) - temp2;
  location++; // increment locations
  if (location >= BUFFER_SIZE) {
    location = 0; // reset location
note the use of ISR instead of AudioCodec_interrupt
and the addition of reti(); at the end to return from the interrupt
i also got rid of the volume adjustment
that can easily be added back in if its not loud enough
and changed the rollover function for BUFER_SIZE
modulo takes forever to run
PostPosted: Sun Apr 01, 2012 11:08 pm
this is a basic version works
comb_filter.pde
guest openmusiclabs 4.1.12
#define SAMPLE_RATE 44 // 44.1Khz
#define ADCS 1 // no ADCs are being used
int left_in = 0x0000;
int left_out = 0x0000;
int right_in = 0x0000;
int right_out = 0x0000;
unsigned int mod0_value = 0x0000;
// create a delay buffer in memory
#define SIZE 800 // buffer size is limited by microcontroller SRAM size
int buffer[SIZE]; // 800 positions x 2 bytes = 1600 bytes of SRAM
unsigned int location = 0; // buffer location to read/write from
  AudioCodec_init(); // setup codec registers
  // call this last if setting up other parts
  int temp1 = location + (mod0_value>>6);
  if (temp1 >= SIZE) {
    temp1 -= SIZE; // reset location
  left_out = ((left_in >> 3) - temp2);
  buffer[location] = left_out >> 1;
  right_out = left_in;
  if (location >= SIZE) {
