Page 3 of 4
Re: getting to know your read/write heads
PostPosted: Fri Sep 09, 2011 7:33 pm
by mitcho
Wow! Thanks for such replies. I should buy you a drink :D
I'm trying to connect the r/w head to a tape head preamp and again found 5 wires connected to it :D It's from a walkman with autoreverse. Did you just pick 2 out of them and everything worked fine? I tried all combinations but not one worked.
PostPosted: Sat Sep 10, 2011 11:24 pm
did you check that the tape deck worked
before doing the mod
the 5 wires are probably as follows
2 for left channel
2 for right channel
1 for case ground
the two channels will probably be
in seperate shielded pairs
make sure to disconnect the wires
from the tape deck head first
then take one of the shielded pairs
and connect them to the floppy head
PostPosted: Wed Sep 14, 2011 8:12 am
by mitcho
Finally, I got rid of the buzz. I connected the FDD heads to the tape head preamp of a walkman. Now I've got a stereo signal. Each channel is on his side of the floppy disk. The signal is still low but can be heard.
Shall we open another thread for the circuit that connects the three FD drives to the arduino?
edit: basically what I did to get rid of the buzz is that I used short wires. as short as possible.
PostPosted: Thu Sep 15, 2011 12:20 pm
congratulations
another thread would be good
PostPosted: Fri Sep 16, 2011 8:33 am
by mitcho
Thank you! :D
Just one more thing. I'm trying to add bias (DC) to the input signal (AC). How did you put them together? An inverting summing circuit like this (http://www.wiringdiagrams21.com/2009/12/03/audio-mixer-inverting-summing-circuit-diagram) wouldn't work because, if I'm not wrong, a capacitor can not pass DC signals. Do you have a diagram of what you did to add bias to the input signal or do you remember maybe how much bias did you add? Thanks a lot for your help.
PostPosted: Fri Sep 16, 2011 11:34 am
you can use the summer amplifier
because the bias you want to add
is actually an AC bias
you need to put a 40kHz signal in
PostPosted: Sat Oct 01, 2011 5:25 pm
by mcanulty
Hey, yeah, I tried running DC through one of the heads because one of the patents I read implied that they were using dc to erase, and that's how I burnt out one of my r/w heads (the only one I managed to burn out actually!). Those little coils don't like to see much current at all.
Guest is quite right, bias frequencies vary, but 40khz is a good start, just get it out of the audible frequency range and mix it with your audio signal. Technically, it helps to get the magnetic media moving around better, so that you can lay down a cleaner signal, but I found it was most especially useful for erasing audio. To make it work I played around until I found a frequency at a resonant peak of my r/w head, but it worked fine with heads that had a different resonant frequency range as well, so I don't think it's a huge deal.
To get a better idea of what's going on, take a look at this link on the GSU hyperphysics site:
http://hyperphysics.phy-astr.gsu.edu/hb ... /bias.html
You can also google "tape bias" for some helpful links.
PostPosted: Wed Oct 05, 2011 9:21 am
by Paleorama
Using a high-frequency tone for erasing is an amazing idea! should it be a certain amplitude to overwrite the existing "data"?
PostPosted: Wed Oct 05, 2011 3:45 pm
by mcanulty
You'll have to experiment with it, it will depend how loudly you wrote your audio data. I found that as I got more acquainted with my system I was able to back off the recording 'volume' or amplitude and which gave me a weaker signal that erased much more easily but didn't cost me in terms of audio quality.
PostPosted: Thu Oct 13, 2011 1:25 pm
by kris_mcdougall
My tape deck actually has three conductors plus a shield/ground. It looks like they combined the negative signals of the two channels together and made: L+, R+, (L+R)- and ground.
EDIT: Looks like this is definitely the case. As other users may encounter the same wiring using cheap cassette decks (mine is a dual cassette Panasonic ghetto blaster from the 80's) I'll share my findings:
L+ = White
R+ = Red
LR- = Yellow
Braid = Ground
This isn't to say that yours will have the same colours, but I hope this will help somebody.
